#1 Posted : Tuesday, 4 December 2007 9:59:34 PM(UTC)
hey just bought a uc-sl torana and im wanting to do a engine swap but a, unsure what engine i should do it with im thinking of a ecotec v6 from a vt commodore but unsure of how much work it will be if anyone has some other engines or could give me some advice it would be greatly appreciated.
JBM Offline
#2 Posted : Tuesday, 4 December 2007 10:27:14 PM(UTC)
JBM
There are a few places that sell kits for V6 conversions into Toranas including Castlemaine Rod Shop (CRS) or another mob in Moree called Gardners. If you want another carby engine a 253/308 will bolt straight in but will need engineering as UCs didnt hav
#3 Posted : Tuesday, 4 December 2007 11:47:43 PM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Originally posted by JBM
You can a get a VN quite cheaply these days and you will get most of the stuff you need and th
JBM Offline
#4 Posted : Wednesday, 5 December 2007 3:11:43 AM(UTC)
JBM
Thanks for that info, are there any TH700s that will run behind a carby motor.
Thanks James
#5 Posted : Wednesday, 5 December 2007 5:16:13 AM(UTC)
Hi James
Any TH700 (not 4L60-E) will work behind a carburettored engine. All you need is something to switch the lock-up converter if you wish to make use of it. You can buy an aftermarket controller or make one yourself. You just need a tacho operated
#6 Posted : Wednesday, 5 December 2007 6:02:31 AM(UTC)
Was thanked: 559 time(s) in 534 post(s)
If you are looking to go EFI I'd use a VN-VSIII 5.0L. Basically a bolt in with only minor mods. And stick a TH350 or M21 behind it meaning no tunnel mods either. This engine will use all standard Torana parts like radiator, sump, engine mounts, radiator h
#7 Posted : Wednesday, 5 December 2007 6:02:31 AM(UTC)
If you are looking to go EFI Id use a VN-VSIII 5.0L. Basically a bolt in with only minor mods. And stick a TH350 or M21 behind it meaning no tunnel mods either. This engine will use all standard Torana parts like radiator, sump, engine mounts, radiator ho
