peterwmh Offline
#1 Posted : Wednesday, 5 December 2007 7:32:51 PM(UTC)
peterwmh
Hi all,
Need a vacuum operated heater valve for my WB statesman as mine is stuck open and I don't really want heat in the cabin this time of year!! So if you have a known good valve I would be interested and happy to pay postage.
Peter
#2 Posted : Wednesday, 5 December 2007 7:42:49 PM(UTC)
If you tell me where exactly to look for this heater valve then i will go check it out as i am currently wrecking a WB Statesman.
Cheers, Luke.
peterwmh Offline
#3 Posted : Thursday, 6 December 2007 12:17:47 AM(UTC)
peterwmh
Hi Luke,
It's the valve located at the front of the engine (usually near the front of the passenger side bank), not far from the idle solenoid (usually) and has a heater hose going in, one going out and a vacuum line hooking into a diaphram on the valv
peterwmh Offline
#4 Posted : Thursday, 6 December 2007 12:17:47 AM(UTC)
peterwmh
Hi Luke,
Its the valve located at the front of the engine (usually near the front of the passenger side bank), not far from the idle solenoid (usually) and has a heater hose going in, one going out and a vacuum line hooking into a diaphram on the valve
peterwmh Offline
#5 Posted : Thursday, 6 December 2007 7:50:21 PM(UTC)
peterwmh
Hi Luke, I dont need this part now as I bought a new V8 commodore one and itll fit and work just fine.
Peter
202 and three on the tree, cant get more Aussie than that!!
peterwmh Offline
#6 Posted : Thursday, 6 December 2007 7:50:21 PM(UTC)
peterwmh
Hi Luke, I don't need this part now as I bought a new V8 commodore one and it'll fit and work just fine.
Peter
#7 Posted : Friday, 7 December 2007 1:55:23 AM(UTC)
No worries,
I had a good look around but couldnt find it..
Engine/Trans is already out so it may have been discarded..
Cheers, Luke.
#8 Posted : Friday, 7 December 2007 1:55:23 AM(UTC)
No worries,
I had a good look around but couldn't find it..
Cheers, Luke.
