basketcasebear Offline
#1 Posted : Thursday, 6 December 2007 5:37:49 AM(UTC)
basketcasebear
hey yall,
Next week I will be having to remove a axle from a au wagon,
I also have to take the tail shaft off, and it might have to be used again,
My question is> is the tail shaft on an au, where it meets the diff, one of those pressed in ones, and if so, what is the best way to get the shaft off??
if it is a bolted on one, then its ok? i am sure i can do that,! just not sure about the pressed ones?
thanks already.
ptpro
madmax transit, 308t400 campervan
DOH!!!
#2 Posted : Tuesday, 11 December 2007 4:40:45 AM(UTC)
basketcasebear
its ok!!
had a look under one today, and it is bolted on at the back, and slides in at the front?
thanks
ptpro
DOH!!!
#3 Posted : Wednesday, 12 December 2007 2:35:40 AM(UTC)
15 & 18mm ring spanners are needed from memory and those bolts should be bloody tight.
A good way for state governments to raise revenue would be for
#4 Posted : Wednesday, 12 December 2007 6:19:29 AM(UTC)
basketcasebear
thanks jim,
I will be taking my box with an, incredible arrangement of mechanical instruments, bound to be a ring spanner or two in there??
hope??
ptpro
DOH!!!
