Go looking for anyone wrecking 1970's and early 80's C20, K20 or C30 trucks. The 292 was standard in the ones sold new by Holden, although some C20's had 350 V8's. If you find a standard 1978-1980 C20 with it's original 350 it is also a good thing to have |
Go looking for anyone wrecking 1970s and early 80s C20, K20 or C30 trucks. The 292 was standard in the ones sold new by Holden, although some C20s had 350 V8s. If you find a standard 1978-1980 C20 with its original 350 it is also a good thing to have as t |
sorry, the link is here http://home.iprimus.com....blast//Turbo202trana.htmdoes anyone know how he did the oil gallery mods?
If it doesn’t burn fossil fuels, it’s not a sport.
500 rwhp. I dont know what to say? I have 180'ish rwhp with a 7 psi supercharged 202, so that is interesting. |
500 rwhp. I dont know what to say? I have 180ish rwhp with a 7 psi supercharged 202, so that is interesting. |
you dont have to say anything, i think i heard your jaw hit the ground anyway. The thing i really want to know is what he did to port his oil galleries. do you reckon he just drilled them out?
If nissan motorsport is nismo, then d
you don't have to say anything, i think i heard your jaw hit the ground anyway. The thing i really want to know is what he did to port his oil galleries. do you reckon he just drilled them out?
I just copied this [from 1986 SM magazine photo shoot]
Engine:
* Block: 202 + .030, X-Rayed, Tension Plate Bored & Honed, Line Bored, Mains & Head Stud Kit * Crankshaft: Fully Counterweighted, Magnafluxed, Balanced Tuftrided, Pro-Street
yeah, i read that, it was very interesting.
but i dont believe the economy for a second. thats about 9L/100km
but i don't believe the economy for a second. that's about 9L/100km
roughly, does anyone know how much it will cost to strengthen an Aussie 4sp?
Probably more than it's worth, honestly. It'd be cheaper for a Muncie or Toploader conversion.
Probably more than its worth, honestly. Itd be cheaper for a Muncie or Toploader conversion.
yeah i'll probably go with a toploader. I've heard you can use an F100 clutch, can this be used with the holden flywheel?
If nissan motorsport is nismo, then doesn't that make honda motorsport Homo? Edited by user Saturday, 15 December 2007 8:09:04 AM(UTC)
| Reason: Not specified
yeah ill probably go with a toploader. Ive heard you can use an F100 clutch, can this be used with the holden flywheel?
If nissan motorsport is nismo, then doesnt that make honda motorsport Homo? Edited by user Saturday, 15 December 2007 8:09:04 AM(UTC)
I doubt it, but your best bet is checking with CRS.
say i did happen to go down the trimatic route, what are the american equivalents, because i heard that the only shift kits are in the USA. T170 or something.
