The Yeti Offline
#1 Posted : Thursday, 6 December 2007 11:30:49 PM(UTC)
The Yeti
As th etitle sugests, will injected VN - VT holden V8 exhaust manifolds fit on early red moter heads, I understand the inlet wount work but I'm interested in the exhaust side of things
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Mr.Jones Offline
#2 Posted : Friday, 7 December 2007 1:42:01 AM(UTC)
Mr.Jones
In a word no
In a few more words. As you have noted the ports are sequentially spaced on the VN on so no more hot spot with the two siamesed centre ports on the red head.
Leroy
Voltaire
The Yeti Offline
#3 Posted : Friday, 7 December 2007 2:25:36 AM(UTC)
The Yeti
OK thanks, does any one have any ideas on another Cast manifold that the passanger side one wont point straigh back, Im running short on fire wall clearance and want to sit the engine as far back as possible
The Yeti Offline
#4 Posted : Friday, 7 December 2007 2:25:36 AM(UTC)
The Yeti
OK thanks, does any one have any ideas on another Cast manifold that the passanger side one wont point straigh back, I'm running short on fire wall clearance and want to sit the engine as far back as possible
sgo Offline
#5 Posted : Friday, 7 December 2007 4:18:41 AM(UTC)
sgo
Maybe use an appropriate drivers side one on the passenger side, should exit at the front?
The Yeti Offline
#6 Posted : Friday, 7 December 2007 6:21:28 PM(UTC)
The Yeti
thinking along those lines but that will be tight also
