bundybluedog Offline
#1 Posted : Friday, 7 December 2007 12:10:45 AM(UTC)
bundybluedog
How do i reset a vp commodore computer
#2 Posted : Friday, 7 December 2007 12:39:45 AM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi bundybluedog.
Reset VP Commodore ? Please explain. What are you trying to do ?
If you want to erase any stored fault code, just disconnect the battery, is that what you mean.
Dr Terry.
#3 Posted : Friday, 7 December 2007 11:10:33 AM(UTC)
bundybluedog
yeah that is what i want to do but a mechanic told me somthing about diconecting it then holding the trotle flat before startup then hold it at 1000 rpm for 30 seconds and i was not sure about it all.
#4 Posted : Friday, 7 December 2007 6:26:10 PM(UTC)
Hi bundybluedog.
Yes, when the stored codes are erased, so too is the memory for the idle speed motor.
On restart, just hold the revs up a bit (1000-1500) then slowly let it down to idle. The ECU will re-learn very quickly. It doesn't matter if you
#5 Posted : Friday, 7 December 2007 6:26:10 PM(UTC)
Hi bundybluedog.
On restart, just hold the revs up a bit (1000-1500) then slowly let it down to idle. The ECU will re-learn very quickly. It doesnt matter if you d
