How do i reset a vp commodore computer |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Hi bundybluedog.
Reset VP Commodore ? Please explain. What are you trying to do ?
If you want to erase any stored fault code, just disconnect the battery, is that what you mean.
Dr Terry. |
yeah that is what i want to do but a mechanic told me somthing about diconecting it then holding the trotle flat before startup then hold it at 1000 rpm for 30 seconds and i was not sure about it all. |
Hi bundybluedog.
Yes, when the stored codes are erased, so too is the memory for the idle speed motor.
On restart, just hold the revs up a bit (1000-1500) then slowly let it down to idle. The ECU will re-learn very quickly. It doesn't matter if you |
Hi bundybluedog.
On restart, just hold the revs up a bit (1000-1500) then slowly let it down to idle. The ECU will re-learn very quickly. It doesnt matter if you d |
