boom Offline
#1 Posted : Saturday, 8 December 2007 5:55:45 AM(UTC)
boom
just reading an old post by byron, what would the compression ratio be if i put 202 4cc dish pistons in? i don't know how to calculate the compression ratio if the pistons are sitting 1/8th down the bore at TDC any ideas?
If it doesn’t burn fossil fuels, it’s not a sport.
#2 Posted : Monday, 10 December 2007 9:57:01 PM(UTC)
If you are trying to lower the compression ratio of a 186 by using 202 pistons eg for turbo/blower application I imagine you'd want flat or dome top 202 pistons (if dome top actually exist?) and a 161/173 head. At a guess this would probably equate to abo
#3 Posted : Monday, 10 December 2007 9:57:01 PM(UTC)
If you are trying to lower the compression ratio of a 186 by using 202 pistons eg for turbo/blower application I imagine youd want flat or dome top 202 pistons (if dome top actually exist?) and a 161/173 head. At a guess this would probably equate to abou
JBM Offline
#4 Posted : Monday, 10 December 2007 10:13:02 PM(UTC)
JBM
The comp ratio is the swept voulme (bore x stroke) divided by the total combustion chamber volume.
ie: Bore x Stroke
Bore Volume Above Piston + Piston Dish + Head Cha
JBM Offline
#5 Posted : Monday, 10 December 2007 10:28:30 PM(UTC)
JBM
boom Offline
#6 Posted : Monday, 10 December 2007 11:56:22 PM(UTC)
boom
pin height is the same. changed my mind. gonna use a 202 for the turbo idea.
#7 Posted : Tuesday, 11 December 2007 1:13:46 AM(UTC)
basketcasebear Offline
#8 Posted : Tuesday, 11 December 2007 6:23:02 AM(UTC)
basketcasebear
Hey Doc, Terry
does this mean the air fuel is compressed to 1/8, of its original volume??
or 1/9,,etc etc? whatever the ratio is?
and if so, how does this relate to "bar", the term they use for air compressors, and their efficency??
ptpro
m
DOH!!!
#9 Posted : Tuesday, 11 December 2007 5:45:38 PM(UTC)
Originally posted by fallingbear
Hey Doc, Terry
#10 Posted : Tuesday, 11 December 2007 10:04:38 PM(UTC)
basketcasebear
Hey thanks doc.
another question>> a small model eg, aeroplane etc,,engine, can it still produce the same amount of compression?
and if so, would this mean if one had say ten 20cc engines, it would still equal the same as having 1 200cc engine, th
DOH!!!
#11 Posted : Tuesday, 11 December 2007 10:34:45 PM(UTC)
Hi fb.
Youve asked 3 questions in one this time.
Yes, 10 x 20cc engines will have the same swept volume as 1 x 200cc engine. But compression figures will differ.
What many people confuse is the comparison between the compression ratio & cylinder
#12 Posted : Tuesday, 11 December 2007 10:34:45 PM(UTC)
Hi fb.
You've asked 3 questions in one this time.
#13 Posted : Wednesday, 12 December 2007 6:07:04 AM(UTC)
basketcasebear
thanks doc!!!
i will have to think about it all for only a little while, to figure it out?? 2>3 weeks!!! but it is very helpful?
ptpro
madmax transit, 308t400 campervan
DOH!!!
