#1 Posted : Friday, 14 December 2007 12:34:11 AM(UTC)
Hi all,
Just bought a 5th month 1973 HQ GTS.
There are no engine , Trans or axle codes stamped on the id plate.
Can any one tell me why? Is this normal?
The other numbers are as follows.
Model: HQ 80469
Body: 104399-A
Trim: 1878-30X
Paint: 568-15893
8N69 UCL 251091Q
as i said no other numbers stamped.
Can anyone help identify the car and tell me about the id tag and why it is not stamped?
Thanks.
JBM Offline
#2 Posted : Friday, 14 December 2007 1:59:10 AM(UTC)
JBM
Not all body plates plates were stamped, some plants stamped all the details and some only 1 or 2 things.
Your VIN indicates a Kingswood Sedan with a 350 engine built in Adelaide between Sept 72 and August 73. All GTS sedans were optioned up Kingswoods.
#3 Posted : Friday, 14 December 2007 2:02:23 AM(UTC)
8N69U the U designates 350 engine
JBM Offline
#4 Posted : Friday, 14 December 2007 2:04:09 AM(UTC)
JBM
#5 Posted : Friday, 14 December 2007 2:48:54 AM(UTC)
Hi guys, thanks for the info.
There is no other number after the body number stamped on the id plate on this car.
Should it have a number?
Are you sure the car is a 350 as it did have a 308 in it.
All the numbers it has is what i have provided.
monaro mark Offline
#6 Posted : Friday, 14 December 2007 3:09:33 AM(UTC)
monaro mark
Hi,
It's definitely a HQ GTS 350 sedan. From memory if the gbox and diff isn't stamped, it's an auto, 3.08 diff. Here is a breakdown of your tags:
80469 = Kingswood body (But the 30X trim designates it as a GTS)
1878-30X = Black Trim
568-15893
Edited by user Friday, 14 December 2007 3:37:33 AM(UTC)  | Reason: Not specified
monaro mark Offline
#7 Posted : Friday, 14 December 2007 3:09:33 AM(UTC)
monaro mark
Hi,
Its definitely a HQ GTS 350 sedan. From memory if the gbox and diff isnt stamped, its an auto, 3.08 diff. Here is a breakdown of your tags:
568-15893 = C
#8 Posted : Friday, 14 December 2007 5:06:53 AM(UTC)
Certainly is a XW8 optioned HQ Kingswood sedan ie GTS350 4 door.
HQ SAND MAN Offline
#9 Posted : Friday, 14 December 2007 5:54:03 AM(UTC)
HQ SAND MAN
Nice find mate !!!!
#10 Posted : Friday, 14 December 2007 6:58:46 AM(UTC)
#11 Posted : Friday, 14 December 2007 6:58:46 AM(UTC)
monaro mark Offline
#12 Posted : Friday, 14 December 2007 8:26:03 AM(UTC)
monaro mark
Hey Dr Terry,
That sounds right, I forgot that my 350 has M41 stamped on the plate. I should have realised. =|
Mark
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim
- HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Blac
#13 Posted : Friday, 14 December 2007 5:52:16 PM(UTC)
HQ GTS.
Looked further into it. The VIN number isnt correct. Email me and I can give you more info.
Terry, you are right that a HQ GTS 4-door is a vehicle in its own right, but its still a Kingswood by model. But then again similar story for SS, Sandm
#14 Posted : Friday, 14 December 2007 5:52:16 PM(UTC)
HQ GTS.
Looked further into it. The VIN number isn't correct. Email me and I can give you more info.
Terry, you are right that a HQ GTS 4-door is a vehicle in it's own right, but it's still a Kingswood by model. But then again similar story for SS, Sa
#15 Posted : Friday, 14 December 2007 6:58:16 PM(UTC)
The bottom of the HQ body id tag is only filled in when an optional driveline is fitted. As a GTS 350 base vehicle is a V8 Kingswood it does have L30 and either MC7 or M41 stamped on the trans section.
A standard GTS/4 has M20 on the tag as the standar
byjingo Offline
#16 Posted : Friday, 14 December 2007 8:01:50 PM(UTC)
byjingo
Its probably a manual.....I have seen examples of other Adeliade built XW-8 manual sedans with out MC-7 on the tags. Does the vehicle have the Muncie hump on the tunnel??
Matt
byjingo Offline
#17 Posted : Friday, 14 December 2007 8:01:50 PM(UTC)
byjingo
It's probably a manual.....I have seen examples of other Adeliade built XW-8 manual sedans with out MC-7 on the tags. Does the vehicle have the Muncie hump on the tunnel??
Matt
#18 Posted : Friday, 14 December 2007 8:16:59 PM(UTC)
I dont think it has a hump in the floor but then again i dont know what to look for and looks to have been an auto, no clutch pedal etc.
What should i look for?
I prefer the auto anyway, but i suppose manuals are rarer.
#19 Posted : Saturday, 15 December 2007 7:12:38 PM(UTC)
I have a HQ and am looking at a hq with 350 in it for the engine. It has engine number v973...ending with a p. Does anyone know if this engine number can prove its a 350 block. Cheers.
Absinth Offline
#20 Posted : Saturday, 15 December 2007 7:28:30 PM(UTC)
Absinth
Sounds like a stolen and recovered engine or the original number has been machined off. VP Victoria Police have issued a new engine number.
This page was generated in 0.120 seconds.
