pdtphil Offline
#1 Posted : Saturday, 15 December 2007 12:29:13 AM(UTC)
pdtphil
Hi again all,
I'm getting a WB Statesman rear bar and just want to ask if it will easily mount to my HJ Van. The van currently has a HZ full rear bar(from a wgn). Can I use the existing irons from the current bar or have to use irons from the WB bar-if so any further drilling etc. I haven't got the bar yet for comparison.
Cheers Phil.G
"If in doubt, Power out"
classic oz wreck Offline
#2 Posted : Saturday, 15 December 2007 1:25:04 AM(UTC)
classic oz wreck
same bar except a couple of holes to mount the rubbers are square...
www.classicozwreck.com.au
pdtphil Offline
#3 Posted : Saturday, 15 December 2007 2:06:30 AM(UTC)
pdtphil
Hey Oz
The rubbers you refer to, are they the strips that are on the bar or should there be rubbers with the brackets
Cheers Phil.G
Rhys Offline
#4 Posted : Saturday, 15 December 2007 3:31:12 AM(UTC)
Rhys
Hi Phil,
The irons/brackets from the rear bar that is on your van at the moment will fit on to the WB Statesman rear bar. The mounting holes on both bars for the brackets are in the same spot. Ive heard people mention before that the tailgate hinges do
Rhys Offline
#5 Posted : Saturday, 15 December 2007 3:31:12 AM(UTC)
Rhys
Hi Phil,
The irons/brackets from the rear bar that is on your van at the moment will fit on to the WB Statesman rear bar. The mounting holes on both bars for the brackets are in the same spot. I've heard people mention before that the tailgate hinges d
pdtphil Offline
#6 Posted : Saturday, 15 December 2007 5:52:39 AM(UTC)
pdtphil
Thanx Rhys, Ill add to this if there are issues with the tailgate hinges, for others to know
Thanx again Phil.G
pdtphil Offline
#7 Posted : Saturday, 15 December 2007 5:52:39 AM(UTC)
pdtphil
Thanx Rhys, I'll add to this if there are issues with the tailgate hinges, for others to know
Thanx again Phil.G
#8 Posted : Saturday, 15 December 2007 10:47:37 AM(UTC)
classic oz wreck
im talking about the rear bar.....they are exactly the same rear bar and the bar itself has different holes because the wb rubber is different...use hq ute/van tailgate hinges as they do not stick out as far and then dont get in the way of the bar...to ge
pdtphil Offline
#9 Posted : Saturday, 15 December 2007 6:17:10 PM(UTC)
pdtphil
Thanx for that clarification Oz.
The wgn bar on it, though, has no extra cuts as you mentioned. I may be lucky with the brackets as they may have modified to avoid. At the moment, the current bar is all alighned properly and clears the hinges OK.
Ha
