jayHK69 Offline
#1 Posted : Monday, 17 December 2007 3:44:53 AM(UTC)
jayHK69
hi,
i`m trying to decide between a powerglide or trimatic to go behind a stock 186 in hg panelvan.
would there be much difference between the two in fuel consumption ?
i live in the blue mountains so half of my driving is uphill.
all opions & advice appreciated
thanks
jayson
#2 Posted : Monday, 17 December 2007 4:01:36 AM(UTC)
Hi jayHK69.
No contest, go the Tri-Matic.
Powerglides are for drag racing, Tri-Matics are for the street. Especially when you're trying to get the best out of a 6 cyl.
The problem with the Powerglide is simply the lack of that intermediate gear d
#3 Posted : Monday, 17 December 2007 4:01:36 AM(UTC)
Hi jayHK69.
Powerglides are for drag racing, Tri-Matics are for the street. Especially when youre trying to get the best out of a 6 cyl.
The problem with the Powerglide is simply the lack of that intermediate gear do
jayHK69 Offline
#4 Posted : Monday, 17 December 2007 4:22:30 AM(UTC)
jayHK69
Thanks Dr Terry
Your advice and help is always appreciated and respected.
Regards
Jayson & Deb
#5 Posted : Monday, 17 December 2007 7:37:11 AM(UTC)
See if you can find an original VK EFI one. They are about the best 6cyl example. It will also shift from a factory HT/G floor shifter, but if you want a column shift a column shift WB 6cyl one will be the best.
________________________________________
jayHK69 Offline
#6 Posted : Monday, 17 December 2007 9:35:56 PM(UTC)
jayHK69
thanks byron, i imagine the vk efi box would have the electric kickdown as mentioned by dr terry ?
#7 Posted : Monday, 17 December 2007 9:39:22 PM(UTC)
All post HG examples do.
boom Offline
#8 Posted : Monday, 17 December 2007 9:55:29 PM(UTC)
boom
why is the VK tri the best? is it simply because of age?
boom Offline
#9 Posted : Monday, 17 December 2007 9:55:29 PM(UTC)
boom
#10 Posted : Tuesday, 18 December 2007 4:54:15 AM(UTC)
Stronger built, like a 253 one. Irrelevant if you are going a full rebuild. Good secondhand box though.
