1xlstu Offline
#1 Posted : Monday, 31 December 2007 5:23:20 AM(UTC)
1xlstu
Can anyone help me out with a water leak inside and outside of my VR. I think it's from the air con unit, only started today, I've got water leaking into the drivers side footwell and more than usual coming out of the outside underneath evap pipe when the air con is on. Just wondering if anyone else has had this problem, and am I up for a new heater unit and all that mucking around removing the dash to do it.
trubluhq Offline
#2 Posted : Monday, 31 December 2007 5:30:36 AM(UTC)
trubluhq
Teh last time I had a VR was that teh drain hoses were blocked, lose, or not connected. The tray the condensation flows into over fills and then enters the foot well with very wet carpet. it floods from behind the carpet from memory.
Check undrneath th
1xlstu Offline
#3 Posted : Monday, 31 December 2007 6:13:43 AM(UTC)
1xlstu
Thanks John, Ill check it out, If its only a blockage Il be rapt.
Stu.
1xlstu Offline
#4 Posted : Monday, 31 December 2007 6:13:43 AM(UTC)
1xlstu
Thanks John, I'll check it out, If it's only a blockage I'l be rapt.
Stu.
