basketcasebear Offline
#1 Posted : Sunday, 6 January 2008 4:25:06 AM(UTC)
basketcasebear
well here we are again, after another super successful project,,with one very minor,, silly thing really,, but i may as well do it..!!! and get it right...
Brakes!!!
I have to bleed them..
diff is in, and workin ripper rita..!!
decades ago, I remember helping a mate bleed his brakes, and I seem to recall, we pumped the brake pedal, and then loosened the bleed nut??
or was it we pumped the brake pedal while we loosened the bleed nut??
HHHMMM?????
please tell me the kirecto mundo sequence.!!
my fellow problemo terminators,
cheers.
by the by,
is it possible to bleed the bleedin brakes, by oneself??
cheers again
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
classic oz wreck Offline
#2 Posted : Sunday, 6 January 2008 4:58:10 AM(UTC)
classic oz wreck
go and buy a suction type brake bleeder and then its possible to bleed them by yourself..also doesnt screw the seal in your master cylinder...start at rear left then go rear right then go front left then go front right and then go for a drive for the fun.
www.classicozwreck.com.au
#3 Posted : Sunday, 6 January 2008 6:07:35 AM(UTC)
basketcasebear
arh thanks oz,,
I will endeavour to attain said suction type brake bleeder on monday monday,,[i dont like mondays],
now as for screwing the seal in my master cyclinder,,!!! did not know they had a seal in there??
and further, it probably isnt very attr
DOH!!!
Fred Offline
#4 Posted : Sunday, 6 January 2008 9:41:20 AM(UTC)
Fred
A one man brake bleeder for about $20.00 was how I last bleed the brakes in our Crown, unbelievably easy and the best job I have ever done.
keithholden Offline
#5 Posted : Sunday, 6 January 2008 10:24:18 AM(UTC)
keithholden
I think you only blow the master cylinder when you dont release the bleeder valve while pushing back the brake pads
#6 Posted : Sunday, 6 January 2008 11:30:16 AM(UTC)
just get a coffe jar or something with a screw top, punch a small hole in the top and feed about 600mm of plastic tube in, make sure it is the right size to go over the bleed valve, about 5/26 i think, make sure the end touches the bottom of the jar.
ut
#7 Posted : Sunday, 6 January 2008 11:52:08 AM(UTC)
basketcasebear
thanks everyone!!
great thinking john perth!!
it will be easier for me to get a self bleeder though, cause of where i am!
i only hope i havent damaged the main cylinder by letting the fluid get to low??
then i will be, bleedin upset!!
ptpro
DOH!!!
