Hey guys.
Just wondering if my chassis number matches my firewall number.
Chassis - 8**37KH555689
Firewall - 44222S S
Im in the process of selling so I need to ID the car properly for future buyers.
Thanks all.
Nathan
These numbers do not match, both started at number 1 on the 1/1/68, ie HK00001SS and H500001
However the HK number progresses by 1 every time an HK enters the line and the H5 number progresses by 1 every time a car enters the line, (HK, HB, Bedford, Ch
What should the firewall number read? I dont really understand??
NathanHK
HK44222SS is your chassis number. 8xx37KH55689 is your VIN number. The xx will be 03, 07 or 18. Just had a quick look through some of my records, and VIN 80737KH5515xx had chassis number HK425xxSS so I'd guess your VIN number would be correct or very Edited by user Wednesday, 9 January 2008 6:45:01 AM(UTC)
| Reason: Not specified |
HK44222SS is your chassis number. 8xx37KH55689 is your VIN number. The xx will be 03, 07 or 18. Just had a quick look through some of my records, and VIN 80737KH5515xx had chassis number HK425xxSS so Id guess your VIN number would be correct or very c Edited by user Wednesday, 9 January 2008 6:45:01 AM(UTC)
do you know what my firewall number should be byron?. i will try and contact the rta but i have a feeling they wont know
NathanHK
There is no way of knowing for sure what the CHASSIS number should be (not called firewall number in HK-HG). All I can tell you is it is close to correct, thus probably is.
_______________________________________________________ If we all had the same |
