chevman Offline
#1 Posted : Wednesday, 9 January 2008 7:18:11 AM(UTC)
chevman
Engine is bored 40thou, flat top pistons, moly rings, new bearings, mild cam, heads are done up for unleaded/gas, engine has not been in a car since being freshend up!! comes with electronic dizzy, starter, alternatore low mount bracket, water pump, fuel pump, engine and trans mount to go into hq-hz etc exstractors! T400 when removed from car was a good strong box c/with converter, flywheel May seperate motor and box but prefer not to! i want $1700 for the lot or closest realistic offer! call for info 0438263393
IF YOU WANT MORE INCHES STROKE IT!!!
#2 Posted : Thursday, 10 January 2008 12:29:08 AM(UTC)
Hi Chevman,
What state are you located in?
chevman Offline
#3 Posted : Thursday, 10 January 2008 5:13:52 AM(UTC)
chevman
im located in victoria, south gippsland.
dean pulham
