#1 Posted : Wednesday, 17 October 2007 12:54:27 AM(UTC)
If anyone is thinking of fitting a rear mount Rack and Pinion to the above vehicles fitted with the 253 or 308 then you will be well aware that you cannot buy extractors to suit. Well you couldn't at the time I fitted ours. As we are now twin turboeing the car the extractors I had made are now longer required. They are brand new and have not been fitted or used. The passengers side was made by Castle Auto Electrics and they supplied the necessary flanges and piping to make the drivers side. They are a unique set and will only fit the holden V8. Looking for $250. They will not fit with a standard steering box. Any questions can be amailed to hg308 at iprimus dot com dot au. Cheers, Glenn
This page was generated in 0.962 seconds.
