the blue and black cranks are better balanced and run smoother than the red but they are heavier and some people find they dont rev as fast, I never found that but I went injected as well. the blue and black con rods are far better than the red, they are
the blue and black cranks are better balanced and run smoother than the red but they are heavier and some people find they don't rev as fast, I never found that but I went injected as well. the blue and black con rods are far better than the red, they are
my 186 is 60thou over which is 192.
thanks for all the help fellas. boom as for the block i would buy it but your to far away thanks all the same. Edited by user Saturday, 19 January 2008 11:39:42 PM(UTC)
| Reason: Not specified
thats cool mate.
thats cool mate.
thanks again fellas next questions. whats an Aussie 4 speed gonna set me back? and how much is a rebuild on one roughly? what sort of pistons do you suggest i use instead of the standard holden ones? include cost etc please and is an after market cam a g
50 bux on ebay. here you go, you get a 186 with it too. http://cgi.ebay.com.au/1...WDVWQQrdZ1QQcmdZViewItem
mate your a legend thanks for that.
next question for anyone interested is the vk 4 speed better than the one from the red motor? will it bolt in the same as the one from the red?
Hi hgkid1.
The gearbox from behind a Red 202 will most likely be an Aussie 4-speed.
VKs were fitted with either an Aussie 4-speed or an MC6 Torquemaster. The Aussie 4-speed is the better box. You will need to change the bellhousing if fitting it to |
