meecar Offline
#1 Posted : Tuesday, 15 January 2008 1:23:11 AM(UTC)
meecar
howdy,
I have a 85 vk 6 cyl auto and have recently put extractors on it.
Since then the car has been having problems when it idles. Drives fine until i need to stop at a light etc. Its also fine in first but when it changes into 2nd or from 2nd it misses and nearly dies. Im not sure but i think it may have something to do with the old manifold having the vacuum on it.
If any1 can help it would be very appreciated.
#2 Posted : Tuesday, 15 January 2008 7:25:32 AM(UTC)
did you block off the openings under the inlet manifold?
If not, when the EGR valve opens it will be sucking in air.
A lot of people aim to achieve nothing in life -
meecar Offline
#3 Posted : Tuesday, 15 January 2008 8:47:19 AM(UTC)
meecar
Hey thanks for the reply,
Our intake manifold is bolted onto the extractors to where the egr would normally go. The only thing that is left over is where to put the hose that would normally join up to the egr.
If you have any other thoughts would you pl
#4 Posted : Tuesday, 15 January 2008 6:33:26 PM(UTC)
Ahhh, OK, so you got the type with the riser tubes (otherwise you have to source blanking plates).
Does it only do it when cold, or all the time?
I know from experience when I fitted them to a blue 6 (many moons ago!) that it would take longer for i
meecar Offline
#5 Posted : Tuesday, 15 January 2008 11:19:51 PM(UTC)
meecar
hey
Yeah was a tad confused-but the egr is connected to the manifold still and has the hose running to the brown tap thing that screws onto the head, I've blocked the hose off that goes to the efe, The car runs pretty bad when cold but still tries to sta
meecar Offline
#6 Posted : Tuesday, 15 January 2008 11:19:51 PM(UTC)
meecar
hey
Yeah was a tad confused-but the egr is connected to the manifold still and has the hose running to the brown tap thing that screws onto the head, Ive blocked the hose off that goes to the efe, The car runs pretty bad when cold but still tries to stal
meecar Offline
#7 Posted : Thursday, 24 January 2008 3:44:59 AM(UTC)
meecar
hey
found out it was the carby so i got another one and had a reverse affect instead of low idles it was reving at 7 on the kpa gauge so now trying to find a good carby
