6pak Offline
#1 Posted : Friday, 19 October 2007 5:54:00 AM(UTC)
6pak
Hi Folks. I've finally fired up the new engine in my Fairlane and have now started working through all the usual teething problems that follow a rebuild. The most concerning problem is a very low brake pedal that drops further when I start the engine. I replaced evrything in the brake syatem with new or reconditioned parts. I've adjusted the rear drums and bled the system. Where else should I be looking? Thanks
