hz dude Offline
#1 Posted : Tuesday, 15 January 2008 9:50:18 AM(UTC)
hz dude
my uncles VN series 1 with the pink engine (if you boys remember)well he
just had the gas tank checked and on the way home came to a stop then took
off and only had 1st gear. could it be the solaniods or vacume mod .
the fuild level is fine and was going fine before this. what might
it be thanx dudes
it's beer o'clock
christoss Offline
#2 Posted : Friday, 18 January 2008 8:31:48 AM(UTC)
christoss
Check the kickdown cable/throttle cable and reset if required, T700's regularly suffer from a sticky throttle valve in the valve body there is an upgrade that consists of fitting a spring behing the throttle valve to hold it firmly against the throttle ca
christoss Offline
#3 Posted : Friday, 18 January 2008 8:31:48 AM(UTC)
christoss
Check the kickdown cable/throttle cable and reset if required, T700s regularly suffer from a sticky throttle valve in the valve body there is an upgrade that consists of fitting a spring behing the throttle valve to hold it firmly against the throttle cam
