peterwmh Offline
#1 Posted : Tuesday, 15 January 2008 11:44:15 PM(UTC)
peterwmh
Hi all,
My 161 HR wagon paddock car is failing badly (might be time to take this engine off life support!!). Anyway it'll run quite OK at idle (albeit with noisy lifters) but as soon as you put it in gear to take off it will always stall now (ie it makes no power under load). It has a great spark, is timed with timing light, has a good harmonic balancer that hasn't slipped. Would a timing gear that has jumped a cog or two cause this? It blows absolutely no smoke!!
Any help appreciated.
Peter
peterwmh Offline
#2 Posted : Wednesday, 16 January 2008 1:22:13 AM(UTC)
peterwmh
Funny thing I've discovered, the engine will run better without the tappet cover, seems to idle slower and miss more often with the cover installed and bolted down. I'm going to clean out the crud inside the rocker cover and see whether the breather is b
peterwmh Offline
#3 Posted : Wednesday, 16 January 2008 1:22:13 AM(UTC)
peterwmh
Funny thing Ive discovered, the engine will run better without the tappet cover, seems to idle slower and miss more often with the cover installed and bolted down. Im going to clean out the crud inside the rocker cover and see whether the breather is blo
