shortys4711 Offline
#1 Posted : Tuesday, 15 January 2008 11:57:16 PM(UTC)
shortys4711
Hey all
I have a HX with an injected 5.0 VS commodore motor in it, I have just bought 2 turbo's for it and I am about to start geting it all together, before I start making up my own manifolds to run to the turbo's, I was wondering if anyone knows of a place that have the manifolds to suit this sort of project, i dont mind modifing them a bit, i just need them to come forward from the motor so i can bolt each turbo on each side behind the front lights, any help on this would be great. thanks for your time,
Daniel
JBM Offline
#2 Posted : Wednesday, 16 January 2008 1:26:48 AM(UTC)
JBM
Put the stock ones on opposite sides? Whatever you do will need to be custom pipes.
James
boom Offline
#3 Posted : Wednesday, 16 January 2008 8:16:33 PM(UTC)
boom
yeah, that would be the easiest way, or you could try the EZE 10s turbo kit, but i don't know if it would fit HX.
boom Offline
#4 Posted : Wednesday, 16 January 2008 8:16:33 PM(UTC)
boom
yeah, that would be the easiest way, or you could try the EZE 10s turbo kit, but i dont know if it would fit HX.
#5 Posted : Wednesday, 16 January 2008 10:37:31 PM(UTC)
Starr Performance and COME do aftermarket inlet manifolds for the injected 5.0 but I don't know if they do specific turbo ones.
A good way for state g
#6 Posted : Wednesday, 16 January 2008 10:37:31 PM(UTC)
Starr Performance and COME do aftermarket inlet manifolds for the injected 5.0 but I dont know if they do specific turbo ones.
A good way for state go
boom Offline
#7 Posted : Thursday, 17 January 2008 7:49:42 AM(UTC)
boom
i think the best way to do this would be to swap the manifolds around and weld bends on the ends pointing up, with the turbo flanges following. you are in luck because HX's have cavernous engine bays.
[IMG]http://i204.photobucket.com/albums/bb304/alexVK_
Edited by user Thursday, 17 January 2008 7:55:21 AM(UTC)  | Reason: Not specified
boom Offline
#8 Posted : Thursday, 17 January 2008 7:49:42 AM(UTC)
boom
i think the best way to do this would be to swap the manifolds around and weld bends on the ends pointing up, with the turbo flanges following. you are in luck because HXs have cavernous engine bays.
[IMG]http://i204.photobucket.com/albums/bb304/alexVK_s
boom Offline
#9 Posted : Thursday, 17 January 2008 7:57:36 AM(UTC)
boom
the hole/extension below the turbo flange is for an external wastegate (depends on whether your turbos are internal or external wastegate. Externals flow more).
boom Offline
#10 Posted : Thursday, 17 January 2008 7:57:36 AM(UTC)
boom
Guest (7)
