#1 Posted : Sunday, 20 January 2008 5:10:54 AM(UTC)
Hi guys, Need some help ? I have a pretty hot holden 6 producing 171 hp at the back wheels . I ve been told to get a nice set of mandrel bent extractors for it as the xU1 cast iron headers are holding it back from producing more hp . What do you reckon ? Any help much appreciated. Thanks Biga064
#2 Posted : Tuesday, 22 January 2008 8:18:08 PM(UTC)
i knew a few guys with them open wheeled holden 6 drag cars. all had to use early style of head. all of them used the cast iron manifold. as they were getting better times than using extractors.
#3 Posted : Tuesday, 22 January 2008 11:48:56 PM(UTC)
Was thanked: 601 time(s) in 568 post(s)
Holden fitted Extractors to the '73 Bathurst XU-1, so obviously they thought it was necessary. So if you are to produce over 200hp from a 202 I'd do it. The cast headers are good for a strong street engine, but properly done extractors should benefit such
#4 Posted : Tuesday, 22 January 2008 11:48:56 PM(UTC)
Holden fitted Extractors to the 73 Bathurst XU-1, so obviously they thought it was necessary. So if you are to produce over 200hp from a 202 Id do it. The cast headers are good for a strong street engine, but properly done extractors should benefit such a
