Hi guys found a HX GTS (Acacia build) on ebay with A9Y after the model code is this the code for a GTS? TIA Leroy |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
First use of A9Y is VL, option code for Calais Wagon.
Not sure why this tag has that code on it.
Warren
Hi Leroy.
I'm with Warren, I haven't seen that code used for the HX series either.
Is it possible to post a picture of the body plate?
Dr Terry. |
Hi Leroy.
Im with Warren, I havent seen that code used for the HX series either.
Dr Terry. |
Hi guys heres the pic hopefully  Leroy edit not sure what I did wrong but right click>view image Edited by user Monday, 21 January 2008 10:06:34 PM(UTC)
| Reason: Not specified |
Any chance of getting the BODY number on the plate confirmed (hard to read). Ill investigate further.
Any chance of getting the BODY number on the plate confirmed (hard to read). I'll investigate further.
Byron my read of it is 4235 6or8 3B cheers Leroy |
if you can make out the trim code it will tell you if it's a GTS or not. its a 253, Aussie four speed, with Salisbury 3.36:1.
if you can make out the trim code it will tell you if its a GTS or not. its a 253, Aussie four speed, with Salisbury 3.36:1.
Looks like a misprint. The trim is 60A so it wouldn't be a neutral headlining. The car is Deville blue so maybe it has a blue vinyl roof....option code XU9.
Looks like a misprint. The trim is 60A so it wouldnt be a neutral headlining. The car is Deville blue so maybe it has a blue vinyl roof....option code XU9.
