Mr.Jones Offline
#1 Posted : Sunday, 20 January 2008 9:24:22 PM(UTC)
Mr.Jones
Hi guys found a HX GTS (Acacia build) on ebay with A9Y after the model code is this the code for a GTS?
TIA Leroy
Voltaire
#2 Posted : Monday, 21 January 2008 5:38:26 PM(UTC)
First use of A9Y is VL, option code for Calais Wagon.
Not sure why this tag has that code on it.
Warren
#3 Posted : Monday, 21 January 2008 7:18:23 PM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi Leroy.
I'm with Warren, I haven't seen that code used for the HX series either.
Is it possible to post a picture of the body plate?
Dr Terry.
#4 Posted : Monday, 21 January 2008 7:18:23 PM(UTC)
Hi Leroy.
Im with Warren, I havent seen that code used for the HX series either.
Dr Terry.
Mr.Jones Offline
#5 Posted : Monday, 21 January 2008 10:02:40 PM(UTC)
Mr.Jones
Hi guys heres the pic hopefully
Leroy
edit not sure what I did wrong but right click>view image
Edited by user Monday, 21 January 2008 10:06:34 PM(UTC)  | Reason: Not specified
Voltaire
#6 Posted : Monday, 21 January 2008 10:05:24 PM(UTC)
#7 Posted : Monday, 21 January 2008 10:10:49 PM(UTC)
Was thanked: 559 time(s) in 534 post(s)
Any chance of getting the BODY number on the plate confirmed (hard to read). Ill investigate further.
#8 Posted : Monday, 21 January 2008 10:10:49 PM(UTC)
Any chance of getting the BODY number on the plate confirmed (hard to read). I'll investigate further.
Mr.Jones Offline
#9 Posted : Monday, 21 January 2008 10:47:51 PM(UTC)
Mr.Jones
Byron my read of it is 4235 6or8 3B
cheers Leroy
Voltaire
boom Offline
#10 Posted : Monday, 21 January 2008 11:45:30 PM(UTC)
boom
if you can make out the trim code it will tell you if it's a GTS or not.
its a 253, Aussie four speed, with Salisbury 3.36:1.
boom Offline
#11 Posted : Monday, 21 January 2008 11:45:30 PM(UTC)
boom
if you can make out the trim code it will tell you if its a GTS or not.
Absinth Offline
#12 Posted : Tuesday, 22 January 2008 12:33:07 AM(UTC)
Absinth
Looks like a misprint. The trim is 60A so it wouldn't be a neutral headlining. The car is Deville blue so maybe it has a blue vinyl roof....option code XU9.
Absinth Offline
#13 Posted : Tuesday, 22 January 2008 12:33:07 AM(UTC)
Absinth
Looks like a misprint. The trim is 60A so it wouldnt be a neutral headlining. The car is Deville blue so maybe it has a blue vinyl roof....option code XU9.
