nostransport Offline
#1 Posted : Monday, 21 January 2008 12:42:19 AM(UTC)
nostransport
hey guys,,
need help to decipher a casting date on a QR 253 V8 motor
code is either : 6731 or G731
also what is the purpose of the clock and how do you read it... ps i know how to tell the time ,,,, really i do
Alan
Drive carefully! Remember, its not only a car that can be recalled by it's maker
Drive carefully! Remember, it's not only a car that can be recalled by it's maker
#2 Posted : Monday, 21 January 2008 1:05:27 AM(UTC)
Was thanked: 611 time(s) in 578 post(s)
It's probably G131 - 13/7/71. I'll be able to confirm if you post the engine number.
#3 Posted : Monday, 21 January 2008 1:05:27 AM(UTC)
Its probably G131 - 13/7/71. Ill be able to confirm if you post the engine number.
#4 Posted : Monday, 21 January 2008 1:15:15 AM(UTC)
nostransport
hi Byron its QR22138 its from my 8/71 hq gts
cheers Alan
Drive carefully! Remember, its not only a car that can be recalled by its maker
#5 Posted : Monday, 21 January 2008 1:15:15 AM(UTC)
nostransport
cheers Alan
#6 Posted : Monday, 21 January 2008 1:23:46 AM(UTC)
Itll be G131. Early Holden V8s used the US date code system with the month first. Your block would have been cast in July 71 for an 8/71 build.
If we all had the same (good) taste, who would buy
#7 Posted : Monday, 21 January 2008 1:23:46 AM(UTC)
It'll be G131. Early Holden V8's used the US date code system with the month first. Your block would have been cast in July 71 for an 8/71 build.
#8 Posted : Monday, 21 January 2008 1:30:46 AM(UTC)
nostransport
thanks Byron,
just another quick question... whilst chassis no matches compliance plate the body number is 114 counts higher???
chassis AHQ06213M
body 006327M
why the discrepancy
#9 Posted : Monday, 21 January 2008 1:30:46 AM(UTC)
nostransport
thanks Byron,
chassis AHQ06213M
body 006327M
why the discrepancy
#10 Posted : Monday, 21 January 2008 1:56:10 AM(UTC)
Because they have no relation to each other. By body number i assume you mean on the BODY plate?
#11 Posted : Monday, 21 January 2008 2:12:34 AM(UTC)
nostransport
yes and many thanks....
also just found out my car is not on the monaro register so thats another one for the record
cheers alan
#12 Posted : Monday, 21 January 2008 2:12:34 AM(UTC)
nostransport
cheers alan
