#1 Posted : Monday, 21 January 2008 2:33:07 AM(UTC)
Come on guys i thought surely someone out there knows whether cast iron headers or a good set of mandrel bent pipes will give me the best results on a 186 with a ton of work done to it .
#2 Posted : Monday, 21 January 2008 3:44:00 AM(UTC)
a mandril bent system will give better flow than the standard bent units as they keep the same dia through the bends, use this with a sport type muffler with good flow and you should feel it. ask for a muffler that wont `bark` to loud they sound crap.
#3 Posted : Monday, 21 January 2008 4:59:39 AM(UTC)
The original 186S headers are pretty good.
boom Offline
#4 Posted : Monday, 21 January 2008 7:36:13 PM(UTC)
boom
VK 12 port extractors is the best factory exhaust on a holden 6 though.
boom Offline
#5 Posted : Monday, 21 January 2008 7:36:13 PM(UTC)
boom
boom Offline
#6 Posted : Monday, 21 January 2008 7:53:57 PM(UTC)
boom
boom Offline
#7 Posted : Monday, 21 January 2008 7:53:57 PM(UTC)
boom
#8 Posted : Monday, 21 January 2008 10:12:16 PM(UTC)
Depends what you are using it for. 186S headers work just as well for street use. And the 73 XU-1 extractors are good too, probably better than VK, and they wont crack like VK ones.
If we all had
#9 Posted : Monday, 21 January 2008 10:12:16 PM(UTC)
Depends what you are using it for. 186S headers work just as well for street use. And the '73 XU-1 extractors are good too, probably better than VK, and they won't crack like VK ones.
If we all h
peterwmh Offline
#10 Posted : Monday, 21 January 2008 10:16:43 PM(UTC)
peterwmh
Also the small matter that VK ones wont fit on a 186 (9 port head) unless you do a blue/black head swap.
Peter
202 and three on the tree, cant get more Aussie than that!!
peterwmh Offline
#11 Posted : Monday, 21 January 2008 10:16:43 PM(UTC)
peterwmh
Also the small matter that VK ones won't fit on a 186 (9 port head) unless you do a blue/black head swap.
Peter
witcheshollow racing team Offline
#12 Posted : Monday, 21 January 2008 10:46:52 PM(UTC)
What you need is a set of tuned length mandrel bent extractors cant get much better with a matching high flow exaust unless you want them ceramic coated. Stainless last longer with unleaded.
"Such is life"
"Such is life"
boom Offline
#13 Posted : Monday, 21 January 2008 11:46:09 PM(UTC)
boom
or a turbo
boom Offline
#14 Posted : Monday, 21 January 2008 11:46:09 PM(UTC)
boom
or a turbo
This page was generated in 0.103 seconds.
