#1 Posted : Monday, 21 January 2008 2:41:15 AM(UTC)
hey my friends got this engine lying around its an old chev.
i just wanted to know a few thinigs i can check to see if itll run alright. its not in a car so cant hear running.
has holley carb, manifold, rollers etc
ive taken the sump off , what should i belooking for ?
boom Offline
#2 Posted : Monday, 21 January 2008 3:05:04 AM(UTC)
boom
turn it over by hand, and if it turns over smoothly without any inconsistancies in tension, then it's probably got a healthy bottom end.
boom Offline
#3 Posted : Monday, 21 January 2008 3:05:04 AM(UTC)
boom
turn it over by hand, and if it turns over smoothly without any inconsistancies in tension, then its probably got a healthy bottom end.
#4 Posted : Monday, 21 January 2008 3:09:00 AM(UTC)
how do i tun it over by hand ???
boom Offline
#5 Posted : Monday, 21 January 2008 7:54:28 PM(UTC)
boom
at the crank.
boom Offline
#6 Posted : Monday, 21 January 2008 7:54:28 PM(UTC)
boom
at the crank.
JBM Offline
#7 Posted : Tuesday, 22 January 2008 2:54:28 AM(UTC)
JBM
Put a socket on the harmonic balancer bolt with a long bar attached to it, if its been sitting for a while spray some oil down the spark plug holes.
James
You only have to be in front at the e
keithholden Offline
#8 Posted : Wednesday, 23 January 2008 6:56:10 PM(UTC)
keithholden
I turned over my chev this way when I got it and it stripped the thread.
Remove plugs first like JBM said this will make it easier as no compression to fight.
