#1 Posted : Monday, 21 January 2008 9:34:03 PM(UTC)
Hi All,
I have a VR commy that has issues with wanting to work correctly. Approx 50% of the time the cruise control and radiator fan will not work. I have check the earthing and that is fine.
I even changed the fan and that didnt do it. All fuses are fine.
I am at a loss of what to check next. The first thing I know about it not working is when the temp gauge starts rising above half.
One time the cruise control started working 30 minutes into a journey.
Any help would be greatly appreciated.
Damo
#2 Posted : Monday, 21 January 2008 10:40:38 PM(UTC)
Hi Damian.
You probably have 2 separate issues here, there is no common connection between these 2.
The most likely cause of the cooling fan problem is either a bad contact at the fan relay base or a faulty fan motor. These things are getting fairly
