#1 Posted : Tuesday, 22 January 2008 2:25:30 AM(UTC)
I have seen HJ GTS dashes with both black and silver facias.
Which is correct?
#2 Posted : Tuesday, 22 January 2008 2:37:32 AM(UTC)
Hi rix66
This was discussed a few weeks ago. It seems that when the HJ was first released only the silver facia was made & this was fitted to any model that had the GTS instruments optioned. Some time during HJ they added black & timber-tone GTS style
Absinth Offline
#3 Posted : Tuesday, 22 January 2008 8:07:46 AM(UTC)
Absinth
Hi Dr Terry, I believe in the HZ series all the GTS fascias were black only. The silver and woodgrain ones finished with the HX.
Absinth Offline
#4 Posted : Tuesday, 22 January 2008 8:07:46 AM(UTC)
Absinth
Hi Dr Terry, I believe in the HZ series all the GTS fascia's were black only. The silver and woodgrain ones finished with the HX.
#5 Posted : Tuesday, 22 January 2008 8:30:30 AM(UTC)
Was thanked: 612 time(s) in 579 post(s)
I have a HZ SL/E Statesman fascia here in front of me. It is identical to a burr-Walnut HX LE fascia but has an RTS badge on it. Also had a HZ Premier GTS dash, which is woodgrain but not Walnut, but is the same wood finish as a normal Premier just a GTS
Absinth Offline
#6 Posted : Tuesday, 22 January 2008 12:43:53 PM(UTC)
Absinth
You are correct Byron, I misread the woodgrain part number in the manual, should have looked at the pictures. The HZ manual is a little confusing at times with the double part numbers in it.
The silver one finished with HX.....unless someone has seen a
#7 Posted : Tuesday, 22 January 2008 6:18:21 PM(UTC)
In 1984 a black one would still be a current part as WB commercials were still on sale until very early 1985.
#8 Posted : Friday, 25 January 2008 7:24:31 PM(UTC)
Thanks for your replies, I have a 1/75 GTS coupe and the fascia is black.I guess if either is correct I may leave it as is.
#9 Posted : Friday, 25 January 2008 10:40:15 PM(UTC)
