keithholden Offline
#1 Posted : Tuesday, 22 January 2008 7:14:11 AM(UTC)
keithholden
This is what I brought and someone asked this question before auction finished this was his answer I paid 655nz for it.
WIDTH IS 1550 END OF AXLE TO END OF AXLE MARKINGS ON TAG ARE WFX-A 3GD 2L 75 9 896E STILL IN CAR AT THE MOMENT CHEERS ROB 1:16 pm, Thu 10 Jan
I have an XW will this fit ??? Just wondering what all the codes mean I searched google with them but it didnt show up any thing
thanks in advance.
#2 Posted : Tuesday, 22 January 2008 7:58:19 AM(UTC)
I beleive it is a 2.75 lsd ratio, will check with 1 I have when I get home.
keithholden Offline
#3 Posted : Tuesday, 22 January 2008 2:37:45 PM(UTC)
keithholden
275 that would be good for high way use would that sound right?. Lsd nice :).
I have an xw and the guy says the width is 1550 end of axle to end of axle. Its a disc break diff. Its at my brothers in the north island at the moment till I work out the c
#4 Posted : Tuesday, 22 January 2008 11:40:27 PM(UTC)
XR-XT rear axle assembly's are 1500 wide XA-EL are 1550 wide. XB was the first model to have rear discs.
Luckily for you the spring saddles stayed in the same place between XY and XA so yes even though it's an XB-XC diff it will still bolt in but
keithholden Offline
#5 Posted : Wednesday, 23 January 2008 6:46:08 PM(UTC)
keithholden
Recon Id get 245/50/14s on the back.. Also it doesnt come with any springs will the standard xw ones be ok or will it require an upgrade.
Ill V8 the car sometime in the future.
Edited by user Wednesday, 23 January 2008 6:47:04 PM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 23 January 2008 11:30:12 PM(UTC)
If you have already got the 245/50/14's under your car just have a look and see if there is room for them to sit an inch further out than they do now.
You can keep your existing rear springs but will have to replace the U bolts as the axle tubes
Edited by user Wednesday, 23 January 2008 11:32:29 PM(UTC)  | Reason: Not specified
keithholden Offline
#7 Posted : Thursday, 24 January 2008 4:57:17 PM(UTC)
keithholden
Forgot to ask. Because its disc brake rear how does the hand brake hook up. Will it be cable??
I have my new Second hand mags in the shed so ill try them on as is and then see what gap there is so when my new diff arrives ill know where I stand. Thanks
Edited by user Thursday, 24 January 2008 5:37:25 PM(UTC)  | Reason: Not specified
Paul351xb Offline
#8 Posted : Thursday, 24 January 2008 7:17:25 PM(UTC)
Paul351xb
I'd check with your tyre suppliers if you are wanting 245s in a 14 inch rim buddy. They aren't making them anymore.
There are 2 types of cable and caliper set ups with the nine inch diffs. As for fitting the hand brake cable it depends what type you ha
Edited by user Thursday, 24 January 2008 7:18:22 PM(UTC)  | Reason: Not specified
keithholden Offline
#9 Posted : Friday, 25 January 2008 4:27:29 AM(UTC)
keithholden
img=http://img85.imageshack.us/img85/1657/xwdiffdiscbrakesvx6.jpg
Pic of the diff its still at my brothers.
Edited by user Friday, 25 January 2008 4:36:23 AM(UTC)  | Reason: Not specified
#10 Posted : Friday, 25 January 2008 8:41:54 AM(UTC)
73 landaus were first released with the disk 9 inch and then xa coupe ! well im near on positive!
Paul351xb Offline
#11 Posted : Friday, 25 January 2008 10:26:21 AM(UTC)
Paul351xb
I'm pretty sure it's an early disc brake set up. So it will be the same as an XB GT or Landau nine inch. Later nine inch disc set ups like the XC had the calipers at the back. Are you really sure you want to put a disc brake set up in the rear of your
keithholden Offline
#12 Posted : Saturday, 26 January 2008 2:53:33 AM(UTC)
keithholden
I didnt think of that I guess brake ballance could be upset if the discs lock on harder than the drums would have. Ill check with safer brakes before i do anything. cheers.
#13 Posted : Sunday, 27 January 2008 10:10:18 PM(UTC)
I agree, XB or Landau style diff. It has the fronnt mounted calipers, the Xcs were rear mounted on the rear. It is also the rounded style housing.
