Hi I am planning to put an aussie box in my vk trimatic. Question is how do I go about installing the clutch cable...I have a manual clutch pedal with a cable to put onto my pedal box is this difficult to do? Can I put this pedal on the box without removing the pedal box? And is attaching the cable to the pedal box/firewall easy? Thanks!
Hi Its me again I have been told 6cyl and 8 cyl clutch pedals are different does anyone know what is different and how I can identify which one I have? Thanks
Hi guys does anyone know anything about converting and early commodore from auto to manual.....???
Hi maccaz69
You will have to change the pedal box, because it has the mounting point for the clutch outer cable to sit, just where it goes thru the firewall hole.
You will have to use the correct clutch pedal for your engine, because the lever lengt |
so, if im running a toploader behind my turbo six VK, do i have to change pedal boxes?
so, if i'm running a toploader behind my turbo six VK, do i have to change pedal boxes?
oh.k thanks.
oh.k thanks.
[quote]Originally posted by boom
oh.k thanks.
If Honda motorsport is Homo, doesnt that make Nissan motorsport Nimo?
oh.k thanks.
If Honda motorsport is Homo, doesn't that make Nissan motorsport Nimo?
