Hey just wondering if anyone has fitted commodore interceptors to hq to wb holdens.I know the pattern is nearly the same and if I reem the center of the rim out to suit will it fit.The thing that I want to know is because the offset is different will it hit on anything.
centre hole is not the problem so much, the pattern pcd is not the same , clearence problems also ,if you start doing the nuts up the wheel will not spin around, if you want 15inch rims go for WB caprice rims or try jaguar xj6 or similar rims (same stud p
The front wheels will hit on the tie rod and the back will fit but doesmt look right . You can buy interceptors to fit with the right off set and centre. have a look on ebay or at any good wheel shop.
its beer oclock |
On The Other Hand There's Finger's |
it's beer o'clock |
Thanks for that fellas wont be getting them in a hurry then.
This may sound strange but it's true they will fit HZ but not HQ the other models i don't know as i have a set on a HZ wagon but they didn't go onto HQ ute , you can get spacers that will allow you to fit all comm wheels and yes i have a set now on the HQ |
He who dies with the most toys wins! |
This may sound strange but its true they will fit HZ but not HQ the other models i dont know as i have a set on a HZ wagon but they didnt go onto HQ ute , you can get spacers that will allow you to fit all comm wheels and yes i have a set now on the HQ ut |
yes, they will fit, but the PCD is slightly different. this means that youre putting extra stress on the wheel studs, and they will snap before long.
yes, they will fit, but the PCD is slightly different. this means that you're putting extra stress on the wheel studs, and they will snap before long.
quote: Originally posted by clubby677
This may sound strange but its true they will fit HZ but not HQ the other models i dont |
This may sound strange but it's true they will fit HZ but not HQ the other models i don' |
Dr Terry it was the ofset and hitting on the top where there is a greese nipple if you know what i mean
i put inters on my old hq ute and they rubbed on everything so i took them to ajax rims in morrabbin in vic. they spun out the centres of the rims and reset the offset from commodore to hq/wb serries cars the holes in the centre of the rims needed to be g
Joined: 4/12/2005(UTC) Posts: 1,062  ![Australia Australia]() Location: western victoria
http://oldholden.com/node/53513"Junk is something you throw out three weeks before you need it" |
Fossil fuels are YUMMY ! |
