80737k Offline
#1 Posted : Saturday, 26 January 2008 5:00:25 AM(UTC)
80737k
I've just bought myself a XT van and intend putting vented discs on to replace the horrid originals plus i'll upgrade the springs and shocks, lowering it at the same time.
Question one, Am i better off with using vented discs with the small hub or get later ones with the big hub ?
Question 2, i read somewhere that by using XA upper control arms, It'll lower my car, Is this true and if so, by how much ?
Question 3, I have a set of Pedders V8 lowered springs and gas shocks out of an XE...These will fit the XT, yes ?
Thanks in advance for any help :-)
"Junk is something you throw out three weeks before you need it"
Fossil fuels are YUMMY !
#2 Posted : Sunday, 27 January 2008 8:45:13 AM(UTC)
answer 1) depends on what wheels u want to put on ie small or large centre . large centred discs are alot cheaper and ezy to get new answer 2)as far as i know changeing top control arms to xa wont lower ur car the only diff i see is the way the ball joint
80737k Offline
#3 Posted : Sunday, 27 January 2008 8:19:05 PM(UTC)
80737k
Thanks mate. Speaking of boosters,I assume the pain in the butt your refering to is the original XT booster ? My XT has tow pot master cylinders and "had" a booster mounted on the passenger side which has been robbed off it. I've a ZC fairlane with a boo
#4 Posted : Monday, 28 January 2008 3:49:52 AM(UTC)
no it wont just bolt in theres a bit of modifying to do cos xw/y zc/d had the booster and pedals moved abit to the left so u might have to cut the firewall out to suit the later master/booster setup ive been told (havent seen it with my own 2 eyes) that w
80737k Offline
#5 Posted : Monday, 28 January 2008 7:45:10 AM(UTC)
80737k
Hmm, Not good news :-( Mine's an auto but i'm putting a single rail in and yet to source a manual pedal box. looks like life aint going to be easy here. I've more work to do on the thing than i first abnticipated but i guess i should know by now that's ho
Guest (5)
