HTMNRO Offline
#1 Posted : Monday, 28 January 2008 8:41:49 PM(UTC)
HTMNRO
I have a nice sedan diff LSD 3.08 that I have cut the hangers off to fit into the tonner. Any way the sedan diff has the smaller yoke and I need to fit the larger one off the Tonner.
Any thing to note when I do this or tips to make it easer.
Or is it a job for the diff joint.
If you want to fight a war you’ve got to have technology. Technology costs money, and money we don’t got. "Running on empty"
#2 Posted : Monday, 28 January 2008 9:03:51 PM(UTC)
Was thanked: 612 time(s) in 579 post(s)
You can do it but they have a collapsable spacer that may prevent you from getting the correct preload on the pinion making the diff noisy. Plus if you have welded the housing the tubes will be bent and need straightening. It will probably need to go to a
HTMNRO Offline
#3 Posted : Monday, 28 January 2008 9:56:44 PM(UTC)
HTMNRO
Thanks Byron,
You’re a wealth of knowledge as always, will do as sugested.
Edited by user Monday, 28 January 2008 9:57:44 PM(UTC)  | Reason: Not specified
