Davesmonaro68 Offline
#1 Posted : Thursday, 31 January 2008 7:58:39 AM(UTC)
Davesmonaro68
Hey guys is there a difference in the master cyl for hktg disc and drum brakes and how do i tell which is which?
Dave
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
hazzard county Offline
#2 Posted : Thursday, 31 January 2008 8:48:19 AM(UTC)
hazzard county
gday dave there is a difference in the internal which can be easily changed but cosmetic outside is the same .you can tell by looking on the big nut should be stamped disc or drum & followed by a dated code.hk t g have the oval shaped lid hq onwards has
#3 Posted : Thursday, 31 January 2008 4:52:44 PM(UTC)
Hi hazzard.
The factory HK/T/G master cylinder is round at BOTH ends.
Dr Terry.
#4 Posted : Thursday, 31 January 2008 6:29:59 PM(UTC)
Davesmonaro68
Dr Terry i thought this was right not having the big nut. Are they the same or not
Dave
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
Custom Offline
#5 Posted : Thursday, 31 January 2008 7:58:55 PM(UTC)
Custom
I would say there would be a difference between the drum and disc unit, possibly the bore size???
Why would you go to all the trouble of rebuilding a car - with all the original mistakes!
#6 Posted : Thursday, 31 January 2008 10:29:31 PM(UTC)
Hi Guys.
If the master cylinder you have has one round end and one square end, it is most probably an aftermarket unit, PBR or similar. This type usually has an alloy housing.
If yours has 2 round ends and no Big Nut it could be one of the very earl
#7 Posted : Thursday, 31 January 2008 10:29:31 PM(UTC)
Hi Guys.
If yours has 2 round ends and no 'Big Nut' it could be one of the very ea
