#1 Posted : Thursday, 31 January 2008 7:50:08 PM(UTC)
hey all has anyone put a 186 head on a 202 red eng would it work ok?? thanks in advance.
Custom Offline
#2 Posted : Thursday, 31 January 2008 7:56:05 PM(UTC)
Custom
Why do you want to put the 186 head on it??
Why would you go to all the trouble of rebuilding a car - with all the original mistakes!
#3 Posted : Thursday, 31 January 2008 9:00:34 PM(UTC)
it has a blown head gasket i tkink or it mybe a cracked head and don,t have a spare 202 head but do have a 186 head sittin around.does anyi out there no?thanks.
#4 Posted : Thursday, 31 January 2008 10:54:06 PM(UTC)
Hi Guys.
Yes, a 186 head will bolt straight onto a 202, even the compression ratio will be the same. One extra advantage is that you will then have adjustable tappets.
What you do need to do, is to use all the pushrods and rocker gear from the 186.
Edited by user Thursday, 31 January 2008 10:55:49 PM(UTC)  | Reason: Not specified
