wildshotz Offline
#1 Posted : Monday, 4 February 2008 12:00:49 AM(UTC)
wildshotz
Hi all.
What is the procedure for filling a dry t400 transmission. By dry, I mean no trans fluid in transmission or torque convertor.
Regards
Dave
hz dude Offline
#2 Posted : Monday, 4 February 2008 5:24:08 AM(UTC)
hz dude
If its still apart .What I do is fill the converter put it back on the
box and put 3-4 litres in the box and slap it all together
( plug all the holes speedo and tailshaft )
and slap it in get it going then check all fluid levels and go from there
Edited by user Monday, 4 February 2008 5:26:55 AM(UTC)  | Reason: Not specified
hz dude Offline
#3 Posted : Monday, 4 February 2008 5:24:08 AM(UTC)
hz dude
If it's still apart .What I do is fill the converter put it back on the
christoss Offline
#4 Posted : Monday, 4 February 2008 9:54:48 AM(UTC)
christoss
just put the auto in car, put about 4.5 litres in then start engine, let run for about 30 seconds switch off then put another 4.5 litres in and start engine select each gear making sure it engages each gear then check level with engine running in park.top
