monaro mark Offline
#1 Posted : Tuesday, 5 February 2008 12:55:28 AM(UTC)
monaro mark
Does anyone know what pound radiator cap a standard HQ 350 used from the factory?
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim
- HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim
Tour Director Offline
#2 Posted : Tuesday, 5 February 2008 1:12:26 AM(UTC)
Tour Director
You need a 15lb cap.A coolant recovery style is better as it allows the water/steam to go to a reservoir and then return when it cools down.
jabba Offline
#3 Posted : Tuesday, 5 February 2008 9:13:54 AM(UTC)
jabba
I can verify recovery system is an improvement. Without, as temp goes up you loose fluid. As temp reduces, it sucks air in, which doesnt perform well in cooling systems.
With recovery system, as it cools down, it draws in morecoolant, which is usuall
jabba Offline
#4 Posted : Tuesday, 5 February 2008 9:13:54 AM(UTC)
jabba
I can verify recovery system is an improvement. Without, as temp goes up you loose fluid. As temp reduces, it sucks air in, which doesn't perform well in cooling systems.
monaro mark Offline
#5 Posted : Tuesday, 5 February 2008 8:21:02 PM(UTC)
monaro mark
My Monaros:
keithholden Offline
#6 Posted : Saturday, 9 February 2008 12:50:09 AM(UTC)
keithholden
Hay Jabba where did you get the overflow bottle and what pressure cap do you run with it ,is 15pounds right as said above for this set up cheers.
