#1 Posted : Tuesday, 5 February 2008 5:25:05 AM(UTC)
Hi, on the edelbrock carb which way should i turn the mixture for lean. at the moment when I turn the screw out it runs leaner. is this normal.
Cheers peter
Davesmonaro68 Offline
#2 Posted : Tuesday, 5 February 2008 7:07:57 AM(UTC)
Davesmonaro68
Depends on which model you have there are two diff types
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#3 Posted : Tuesday, 5 February 2008 8:17:32 AM(UTC)
600 performer series.
#4 Posted : Tuesday, 5 February 2008 10:26:50 PM(UTC)
Davesmonaro68
what model no peter 1406 or if it has no no on it it will be an early one
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#5 Posted : Wednesday, 6 February 2008 4:51:13 AM(UTC)
1405.
cheers peter
#6 Posted : Wednesday, 6 February 2008 8:39:30 AM(UTC)
Davesmonaro68
1405 should be rich if you turn screw out unless its been modified . Pull the mixture srcew right out and see if its got a needle point or flat blunt end with a a tappered grove further back from the very end . If its a needle end then its a normal mixtur
MONARO!!WHERE!!NICE
