I have a rear cut off a tonner here in Newcastle. It's pretty good too. Cut through the windscreen pillars and across the middle of the floor under the seats. Nice and cheap too. Just time cosuming to get down of the mezzanine.
________________________ |
I have a rear cut off a tonner here in Newcastle. Its pretty good too. Cut through the windscreen pillars and across the middle of the floor under the seats. Nice and cheap too. Just time cosuming to get down of the mezzanine.
_________________________ |
just go with the V8, i'll bet your wife won't even be able to tell.
just go with the V8, ill bet your wife wont even be able to tell.
Boom i will stick with the 6 probably a petrol similar to what adam perth and byron have sugested which is the simplest and cheapest, LPG would be nice but i dont have the setup for it, I want to spend about 2500-3000 thats body paint drive line and inter |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Yes it does. It's got a small amount of rust, but the roof itself is rust free but has a dent in it I was going to build a 4x4 tonner out of a GQ Patrol, and this was the cab for it - just needed a firewall cut. But the Overlander came up and I never buil |
Yes it does. Its got a small amount of rust, but the roof itself is rust free but has a dent in it I was going to build a 4x4 tonner out of a GQ Patrol, and this was the cab for it - just needed a firewall cut. But the Overlander came up and I never built |
Thanks for the offer byron but wouldnt be able to get down there anytime soon. |
It ain't going anwhere in a hurry. Will probably be there is 2 years.
It aint going anwhere in a hurry. Will probably be there is 2 years.
i did a cheap upgrade to a vh comm.with a blue 202 keep it simple genie extractors 2.5 inch exh. 1 muffler 1 resonator and a 350 holley then played with jets till i got a good compramise plenty of power and ok fuel econ.
weber will probably work better than holley.
