#1 Posted : Wednesday, 13 February 2008 8:31:53 AM(UTC)
I have an 85 XF with a 4.1 carburettored motor. It has an annoying intermittant problem. It can be started with no problems (hot or cold) and will happily idle. If started from cold it can be driven through stop start traffic with no problem. If I stop the engine when it is warm and restart it the engine will stall when I put it in drive. If I use a bit of accelerator I can get it moving but it will continue to stall every time I stop until I get up to around 40-50km/h then it is OK. Any thoughts?
#2 Posted : Thursday, 14 February 2008 2:16:34 AM(UTC)
First thought would be vapour lock especially if the weather is warm. Second would be fuel pump getting sluggish due to worn/sticky valves. Third one could be sticking needle and seat possibly caused by ethanol blend petrol eating the rubberised needle ti
sparkzy Offline
#3 Posted : Sunday, 24 February 2008 1:26:46 PM(UTC)
sparkzy
This happend to me check if your running on all pistons as I had 5 running due to 1 spark plug broken, it was the last thing I thought it could be but **** happens....
I had a hair line crack in 1 plug and replaced it and all good.
Edited by user Sunday, 24 February 2008 1:28:11 PM(UTC)  | Reason: Not specified
FORD MUSCLE
XFDAZA Offline
#4 Posted : Friday, 28 March 2008 11:22:39 AM(UTC)
XFDAZA
I had it in to the mechanic who though a tune would solve the problem. Replaced plugs, leads, distributor cap and rotor. No change though so not a plug problem. Thanks anyway Sparkzy. Every tip helps.
Also noticed before and after tune that it is smokey
Edited by user Sunday, 30 March 2008 8:51:54 PM(UTC)  | Reason: Not specified
Dmax Offline
#5 Posted : Friday, 28 March 2008 6:59:54 PM(UTC)
Dmax
I would check your timing, and auto choke to make sure it's turning off properly. Both these things can effect idling once the car is warm and/or make your car run rich.
648hp Tunnel Rammed 351, It does not get any better
[img]http://i79.photobucket.
#6 Posted : Sunday, 8 June 2008 8:50:00 AM(UTC)
idle stop solenoid come to mind.
mine was doing something similar......found it today... idle stop solenoid open circuit.
it will run under choke as the main jets will be active.
also check that the dual idle jet arrangement is functioning.
the
#7 Posted : Sunday, 22 June 2008 11:01:06 AM(UTC)
Replace carby i had the same problem with my xf. I CHANGED 2 A SECEND MOTOR AND HAD THE SAME PROBLEM .I HAD 2 keep advancing tha dissy untill i replaced tha carby
This page was generated in 0.098 seconds.
