BlaDe Offline
#1 Posted : Wednesday, 7 November 2007 9:59:25 AM(UTC)
BlaDe
Hi guys i have a few questions
1 What color should the horn ring on a HQ with power steering be, or what sort of gap should there be between both canceling posts the one i have now there is only around 12mm, also how do i line up the ring properly, as it is now it wont cancel on left turns but cancels to soon on right ones
2 When i put in the power steering i had to use a drag link from a HZ, are they diff between HQ to HZ? also is the tie rod between both models diff?
3 And last but not least i have noticed that it only takes one complete turn of the steering wheel from center to get to full lock turning right but it takes 1 3/4 turns from center to turn left, am i missing something or did i stuff something up when i put the power steering in?
Cheers for any help you guys can offer
Blade
Edited by user Wednesday, 7 November 2007 10:59:55 PM(UTC)  | Reason: Not specified
