#1 Posted : Thursday, 14 February 2008 7:06:23 AM(UTC)
hey im putting together a sbc , i just went out today to get the centre bolt for the balancer , to find it doesnt seem to need one
whats the go here
there is no thread inside
plz help
\cheers
boom Offline
#2 Posted : Thursday, 14 February 2008 7:11:47 AM(UTC)
boom
it's press fit.
boom Offline
#3 Posted : Thursday, 14 February 2008 7:11:47 AM(UTC)
boom
its press fit.
jabba Offline
#4 Posted : Thursday, 14 February 2008 5:35:23 PM(UTC)
jabba
The centre bolt goes into the end of the crank with a big washer to hold the balancer on. The balancer should have a keyway (slot) that lines up with a key (or lump of metal) on the crank. Line up the key with the slot, slide on, and then put in bolt an
#5 Posted : Thursday, 14 February 2008 7:07:33 PM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi jabba.
Early SBCs, like the 327 & 350 engines fitted to HK/T/G didnt have the centre bolt in the crank or even a threaded hole. The bolt & washer came with later SBCs.
Dr Terry.
#6 Posted : Thursday, 14 February 2008 7:07:33 PM(UTC)
Hi jabba.
Early SBCs, like the 327 & 350 engines fitted to HK/T/G didn't have the centre bolt in the crank or even a threaded hole. The bolt & washer came with later SBCs.
Dr Terry.
jabba Offline
#7 Posted : Thursday, 14 February 2008 7:10:47 PM(UTC)
jabba
Well, there you go. You learn something new every day.
Cool.
Sandman Offline
#8 Posted : Friday, 15 February 2008 8:52:14 AM(UTC)
Sandman
Even if it's an early crank that is not tapped for a bolt, it is worthwhile getting a thread tapped into the crank so that you can fit one.
The thread size is 7/16 UNF.
It's a pretty expenxive exercise repairing an engine that the balancer has come loo
Sandman Offline
#9 Posted : Friday, 15 February 2008 8:52:14 AM(UTC)
Sandman
Even if its an early crank that is not tapped for a bolt, it is worthwhile getting a thread tapped into the crank so that you can fit one.
Its a pretty expenxive exercise repairing an engine that the balancer has come loose
