basketcasebear Offline
#1 Posted : Friday, 15 February 2008 8:53:25 AM(UTC)
basketcasebear
in this exciting episode,BCB is wondering about the capacity of the different electrical cables to carry current.
my riveting question is>>>>>
is 240volt x 10amp cable bigger, stronger, more capacity,,than>>
12volt x 10amp..????
if so, what capacity does the 240voltx10amp equate to?? re 12v??
thanking you
BCB
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
Edited by user Friday, 15 February 2008 9:01:07 AM(UTC)  | Reason: Not specified
DOH!!!
#2 Posted : Friday, 15 February 2008 5:27:50 PM(UTC)
Current and insulation level is all that matters with cable. 10A is 10A regardless of voltage, assuming the insulation is suitable. Low voltage cable (in AC low voltage is 50V to 1000V) is expressed in terms of insulation to earth/line eg 0.6/1kV cable is
Edited by user Friday, 15 February 2008 5:28:49 PM(UTC)  | Reason: Not specified
#3 Posted : Friday, 15 February 2008 6:54:31 PM(UTC)
basketcasebear
hey byron,
umm after reading your reply, and i thankyou for it, i have realized my wiring in my brain is not high volume!! as in trying to take all that imfo in, i think i blew a fuse?
the reason i had asked was, i remember someone telling me once, that
DOH!!!
#4 Posted : Friday, 15 February 2008 8:38:23 PM(UTC)
multiply amps by volts give you the wattage rating, used for appliances, eg 100 globe/ 2kwatt heater, wire only cares about amps carried and insulation protecting it from earthing
if using 240 volt wire in auto best to use 1.5 to 2.5mm square multistrand
#5 Posted : Saturday, 16 February 2008 12:57:25 AM(UTC)
You can buy flexible V105 wire from electrical wholesalers. It would do the job.
ozchevy Offline
#6 Posted : Saturday, 16 February 2008 7:07:37 AM(UTC)
ozchevy
If you pick up an Olex pocket book catalogue from an Electrical wholesaler, you will find all types of cable from flexible multi strand through to heavy welding cable which is suitable for battery connection. The Olex pocket book is available free of char
#7 Posted : Sunday, 17 February 2008 1:36:50 AM(UTC)
Also online.
#8 Posted : Sunday, 17 February 2008 5:43:29 AM(UTC)
basketcasebear
thanks everyone, i will tape and protect the wiring i have done, betterer,
but feel it should be okie dokie.
BCB
ptpro
DOH!!!
#9 Posted : Sunday, 17 February 2008 7:35:21 AM(UTC)
I know very little about leccy but as a rule of thumb if the wires are getting very warm or hot they are too small. the heat is wasted power and the appliance is not getting full power. use larger wire. or double it in the case of figure 8 (normal househ
#10 Posted : Sunday, 17 February 2008 7:46:31 AM(UTC)
basketcasebear
hey john perth,
I went to bunnings, and being a tightrrse, bought one of those 15amp 20mtr, power leads, for $15,
gave me about 60mtrs of coloured striped cable,?
thats why i was asking, about current capacity. but it is fairly thuck, as the kiwis wou
DOH!!!
Sandman Offline
#11 Posted : Monday, 18 February 2008 9:43:10 AM(UTC)
Sandman
Volts X Amps = Watts
Watts / Volts + Amps.
Therefore if your going to run a pair of 100wat spotlights on you car, you divide 200watts(2lights) by 12 so thats 16.6666666, so you should run 20amp wire.
Works the same for 240. Which is why most heaters et
#12 Posted : Monday, 18 February 2008 9:39:43 PM(UTC)
Not that simple for AC. Actual AC power measured in VA (or often kVA) is AC volts x AC current for single phase, and volts x current x sqrt3 for 3 phase. In AC systems Watts is referred to as real power and is equal to the Power in VA multiplied by the po
#13 Posted : Tuesday, 19 February 2008 6:09:41 AM(UTC)
basketcasebear
you have done it again Byron!!
testing out the wire capacity in between my ears!!!
overloaded..!!!
anyways thanks, I reckon the wire i have used, is okies, cause it is at least 2>3 times thicker than than the wires into the motor!!!
might be a tadd
DOH!!!
Mechatron Offline
#14 Posted : Friday, 22 February 2008 7:41:10 AM(UTC)
Mechatron
speaking of electricity, this is a nice video
[url="http://www.youtube.com/watch?v=HcalasGr_uk"]bird on a wire [/url]
Browno Offline
#15 Posted : Friday, 22 February 2008 8:07:48 AM(UTC)
Browno
HOLY
Drive It Like You Stole It......Drive it like you own it
kraul Offline
#16 Posted : Wednesday, 27 February 2008 9:39:50 AM(UTC)
kraul
simply ac cable is different to dc cable. its best to stick to the wire for the job. makes it simple and prevents problems. im not going to dive into the differencesbut there are some so best be and for safety stik to the right wire and dont cut corners
#17 Posted : Wednesday, 27 February 2008 9:51:39 AM(UTC)
basketcasebear
hey kraul,
whats the diff between ac cable, and dc cable??
i know house ac cable is different,,
but the cable I have used is copper, and far thicker than the normal cable found in most elec situations i have seen in cars?
it is a minimum of least 2 ti
DOH!!!
