musksell Offline
#1 Posted : Friday, 15 February 2008 6:28:16 PM(UTC)
musksell
I've been told that when the factory brought out the 253 it had thicker cylinder walls than the 308, because they planned to bore it out later.Hence iot would be alot stronger for turbo or supercharging/stroking.
true or false....?
JBM Offline
#2 Posted : Friday, 15 February 2008 6:45:09 PM(UTC)
JBM
Have a look at this topic regarding bore wall thicknesses and maximum bore sizes. Its best to get indivdual blocks tested before you decide how big to make the bores as core shift can be a problem with cast iron items.
http://www.gmh-torana.com/forums/
musksell Offline
#3 Posted : Friday, 15 February 2008 7:48:02 PM(UTC)
musksell
interesting article, they reckon 253 had bores 6mm to 8mm and could be bored to 98.42mm, where as a 308 only has 2mm to 4mmm...?
JBM Offline
#4 Posted : Friday, 15 February 2008 7:54:48 PM(UTC)
JBM
A 308 bore is 4" (101.6 mm) and the 253 is 3.625". The difference in overbore capacity is because youre starting with a smaller bore with the same cylinder spacing in the 253.
James
You only h
Edited by user Friday, 15 February 2008 7:59:30 PM(UTC)  | Reason: Not specified
trubluhq Offline
#5 Posted : Friday, 15 February 2008 8:51:50 PM(UTC)
trubluhq
Is the 253 & 308 the same cast ? Just machined differently ??
John
JBM Offline
#6 Posted : Friday, 15 February 2008 9:05:43 PM(UTC)
JBM
The core for the water jacket may be different because you cant take a 253 bore out to 4". The outside dimensions are the same and would have been a common pattern with the different engine size cast mark pattern insert being removable to suit the inner c
musksell Offline
#7 Posted : Friday, 15 February 2008 9:23:18 PM(UTC)
musksell
No I meant the cylinder casting itself not the bore was supposed to be thicker on 253 from the factory, a bit like a diesel.
#8 Posted : Saturday, 16 February 2008 2:38:59 AM(UTC)
speedway has a catagory running only useing 253 red motors theirs hundreds in it so their going to need need 253s on an on going bases one would think plus i hate the thought ofv junking them cheers
#9 Posted : Sunday, 17 February 2008 5:09:39 PM(UTC)
personaly I like the 253 over the 308, I dont know why becasue on paper it really is a piss poor option but it just has a querky feel to it, its really hard to explain,
does any one have any build information for the speedway or commodoor cup 253s
#10 Posted : Sunday, 17 February 2008 5:09:39 PM(UTC)
personaly I like the 253 over the 308, I dont know why becasue on paper it really is a piss poor option but it just has a querky feel to it, it's really hard to explain,
does any one have any build information for the speedway or commodoor cup 253's
