just out of interest, how much are VN-VT 304 blocks going for. obviously the clearanced and roller blocks are more, but how much do you reckon a block would go around?
and i've heard speed pro pistons to suit 350 stroker cranks go for around $9 from summit racing in the US, is this right? they are only cast after all.
Thanks: 1 times Was thanked: 559 time(s) in 534 post(s)
$300. A complete shagged motor with no accessories ia about $600.
i checked up on the pistons, and this is correct for cast pistons, $11 ea. Forgies are $35 ea, I beams are $260, H beam rods are $429 all in USD, but couple that with an eagle 355 crank, and you have a very good bottom end that costs F*$$ all. Boost Edited by user Sunday, 17 February 2008 8:35:02 PM(UTC)
| Reason: Not specified
Maybe they dont trust the aussie 4spd or trimatic and 10 bolt to handle 350 cubes?
Maybe they don't trust the aussie 4spd or trimatic and 10 bolt to handle 350 cubes?
i wouldn't. this is what i will do: 355TT/Toploader/28spline B/W.
the new COME 396 kits are $3300. pretty good.
i wouldnt. this is what i will do: 355TT/Toploader/28spline B/W.
Yeah, but consider an original SLR5000, Brock Commodore, Sandman or original auto HT/HG GTS. You couldn't fit the Top loader (or Muncie even stronger) without butchering the body. And an M21 is already stressed enough. So in that case the 308 rebuild make |
Yeah, but consider an original SLR5000, Brock Commodore, Sandman or original auto HT/HG GTS. You couldnt fit the Top loader (or Muncie even stronger) without butchering the body. And an M21 is already stressed enough. So in that case the 308 rebuild makes |
sorry byron, i've forgotten about torana and pre HQ owners, i was thinking from more of a commodore point of view. the guys on streetcommodores.com running 355s are making 500+ naturally aspirated with only 9:1 comp. ready for Forced induction. one of whi
sorry byron, ive forgotten about torana and pre HQ owners, i was thinking from more of a commodore point of view. the guys on streetcommodores.com running 355s are making 500+ naturally aspirated with only 9:1 comp. ready for Forced induction. one of whic
Yes, but the Holden engine has a better standard head, but having said that good heads for the SBC are not dear. For serious hp the SBC has a much better aftermarket industry. If it was for a street car though you cant really go past a stroked Holden engi |
Yes, but the Holden engine has a better standard head, but having said that good heads for the SBC are not dear. For serious hp the SBC has a much better aftermarket industry. If it was for a street car though you can't really go past a stroked Holden eng |
that's right, also to convert the motor to EFI costs far less. you don't even need the Bananas anymore, just get a 4bbl carby style throttlebody and bolt it to the existing manifold. http://forum.streetcommo...howthread.php?t=8519521
like t
thats right, also to convert the motor to EFI costs far less. you dont even need the Bananas anymore, just get a 4bbl carby style throttlebody and bolt it to the existing manifold. http://forum.streetcommo...howthread.php?t=8519521
like tha
