JYJ003 Offline
#1 Posted : Monday, 18 February 2008 3:40:59 AM(UTC)
JYJ003
My elderley father has an EA S pack 110km friom new. Normall running ot a problem, but when the AC is on, it overheats rather rapidly, Any suggestions?
ted
6pak Offline
#2 Posted : Monday, 18 February 2008 6:00:17 AM(UTC)
6pak
Hi. My old EA started to show this symptom as well. I had the radiator pulled apart and cleaned (rodded) and it was good to go after that. Even though it's low mileage they can still clag up.
#3 Posted : Tuesday, 19 February 2008 12:09:50 AM(UTC)
Yes apparently they left sand in the blocks during manufacture which eventually finds it's way into the radiator and blocks it.
My EB suddenly started overheating after I changed the water pump. I removed the radiator and reverse flushed it using a
JYJ003 Offline
#4 Posted : Wednesday, 20 February 2008 10:10:15 PM(UTC)
JYJ003
Thanks Guys, looks like a pressure flush and a new radiator, cheers Ted
#5 Posted : Friday, 21 March 2008 10:05:29 PM(UTC)
the space between the radiator and air con condencor coil holds debris and clogs up. a known problem with the E series falcons. remove the 2 bolts holding the radiator in place and push it towards the engine block. you need to blow out the buildup with co
