meecar Offline
#1 Posted : Monday, 18 February 2008 9:24:54 PM(UTC)
meecar
howdy
just wondering with the vn-vp-v6 conversion into vk, i know the vn-vp K frame fits but i want to know if the v6 would fit if i left the vk K frame in.
and any other info about v6 conversion would be great.
#2 Posted : Monday, 18 February 2008 10:59:02 PM(UTC)
Swapping the K frame is easy however if you want to keep your K frame both V6 Conversions and CRS will sell you brakets that bolt on to the v6 block and use standard red/blue/black mounting rubbers onto your EH-VK (up to VT1 if V8) front end but they
#3 Posted : Monday, 18 February 2008 11:01:19 PM(UTC)
Also if you stick with the VK K member you wont be able to use the V6s A/C compressor unless you buy the conversion kit to place it where the V6 power steering pump goes which is a bit untidy IMO.
#4 Posted : Monday, 18 February 2008 11:01:19 PM(UTC)
Also if you stick with the VK K member you won't be able to use the V6's A/C compressor unless you buy the conversion kit to place it where the V6 power steering pump goes which is a bit untidy IMO.
