2 Pages<12
XB351 Offline
#21 Posted : Saturday, 15 March 2008 5:47:32 AM(UTC)
XB351
With that dish you end up with 10.5:1 roughly. I've got the 10cc dish down to 6.5cc and run 11.5:1. Due to the nature of the head design I can run pump fuel without an issue.
#22 Posted : Wednesday, 26 March 2008 10:28:54 PM(UTC)
would it be cheaper to just get a 400 'M' cleveland motor. and go from there. maybe you are after the rod ratio, and intake manifold options? more for drag racing. not the street driven 30000 km a year type that may like to try to get maybe 200000 km out
#23 Posted : Friday, 28 March 2008 9:31:23 AM(UTC)
G'day Cleveland man
You may well be right.
However I have put my money down on what after much research finishes up as the same bottom end as Brenden.
The choice of cam and heads is what will change the characteristics of the two motors.
I am working
XB351 Offline
#24 Posted : Saturday, 29 March 2008 6:06:40 AM(UTC)
XB351
Set up right with a smallish torquey cam the components will last millions of kilometres if looked after (ie not run with no oil etc). My pistons were decked to achieve a high comp ratio but with my setup I can drop to a much smaller hyd roller camshaft a
#25 Posted : Tuesday, 1 April 2008 9:57:24 PM(UTC)
400M might be the way to go if thats what you already have but I think by the time you buy one and rebuild it then you've spent the money that could have paid for a stroker kit!
One of the american mags did a feature on this engine a few months back an
#26 Posted : Wednesday, 2 April 2008 6:00:17 AM(UTC)
I think autos are the go with a 400 ci. the c6 auto is lighter than a fmx.
Ford increased the deck hight of, the 250 6 cyl over the 221 and 200. same with the 302 windsor and 351 windsor. 351 cleveland and 400M. for a reason? i say it's for a less stress
Paul351xb Offline
#27 Posted : Wednesday, 2 April 2008 8:21:33 AM(UTC)
Paul351xb
C6 lighter than a FMX? Are you sure on that? FMX is a car box, C6 is a truck box. I've had to lift both over the years, both clevo ones, and the C6 was a lot heavier from memory.
#28 Posted : Thursday, 3 April 2008 11:45:42 PM(UTC)
#29 Posted : Sunday, 20 April 2008 9:32:31 AM(UTC)
G'day Brenden
I guess you have been here before but I dropped off my bottom end at the balancers and got the phonecall to say that with a standard balancer we need to remove about a Kg from the crank counterweights.
So my flash "race spec" balancer need
#30 Posted : Tuesday, 22 April 2008 5:25:59 AM(UTC)
so does this mean the 250's used in the ford cortina's were american blocks?
Edited by user Thursday, 24 April 2008 10:40:04 PM(UTC)  | Reason: Not specified
#31 Posted : Thursday, 24 April 2008 10:40:29 PM(UTC)
No they used very short connecting rods in essentially 200 blocks. Ford USA did it properly and raised the deck height for the 250.
Some people say I
Edited by user Thursday, 24 April 2008 10:41:06 PM(UTC)  | Reason: Not specified
#32 Posted : Friday, 25 April 2008 8:24:06 AM(UTC)
Hey guys
When did this thread turn into a deck height on a six cylinder question?
#33 Posted : Friday, 25 April 2008 8:45:06 AM(UTC)
just the way a coversation flows?
Browno Offline
#34 Posted : Friday, 25 April 2008 7:22:13 PM(UTC)
Browno
g'day Jim
Just went and measured the 250 precrossflow that a uncle gave me out of a 74 cortina and the 250 is about a inch or so taller then the 221 i have, measuring from where the sump bolts on to the to the deck
You learn something every day.
Edited by user Wednesday, 30 April 2008 1:02:49 AM(UTC)  | Reason: Not specified
Drive It Like You Stole It......Drive it like you own it
XB351 Offline
#35 Posted : Sunday, 27 April 2008 3:41:45 AM(UTC)
XB351
Originally posted by Effie 351
G'day Brenden
Edited by user Sunday, 27 April 2008 4:12:11 AM(UTC)  | Reason: Not specified
#36 Posted : Monday, 28 April 2008 8:20:12 AM(UTC)
G'day Brenden
Already gone the Romac balancer route.
I won't machine my pistons now as the assembly has been balanced.
My reason for going for the 2V heads (including the advice from John at CHI) is that I am chasing more performance at a lower RPM ban
Guest (18)
2 Pages<12
